Gen 2 Double Passenger Seat
Topic Started: Aug 30 2016, 11:55 AM (392 Views)
PhilTheGasman
Simple question, Will double seats from a gen3 fit in a gen2?
johnr
where theres a will, theres a way, ive got toyota mr2 seats in my camper, so you should be able to fit them in.
mckape
I fitted 2004 model seats to my 2000 2nd gen 49/10 bus While they have different base they are not very far out You need to make up an adaptor plate for each seat base I used angle iron cut a little longer than the seat base reverse one plate so when placed together they form a Z Then adjust to suit seat and floor holes tack weld and mark and drill holes weld up And away you go you have used the original mounting holes and bolts in both Ive done 60000 kms no sign of movement and it has passed 4 annual rego checks Iwould have put in adrawingof same but I don't know how to Regards Peter
