| Electric problem Iveco 40-12 1993 | |
| Tweet Topic Started: Sep 7 2016, 10:31 AM (346 Views) | |
| gunhal | Sep 7 2016, 10:31 AM Post #1 |
I have a Iveco daily 1993 and the electric board with the relays and fuses has suffered from overheating. I got a replace electric board, but when i coupled it in the wipers, the blinkers and the fan was not working. The engine starts without problems and the headlights work when i press the separate button, but not through the ignition. I suspect that it is a relay problem maybe E3. Has anyone else had a problem like this and has ideas about how to fix it? |
