| speedo; calibration | |
| Tweet Topic Started: Dec 10 2016, 08:06 PM (338 Views) | |
| Trevskoda | Dec 10 2016, 08:06 PM Post #1 |
Hi i have a 59/12 and just changed diff from 8/41 to 11/43 but teco/speedo is running slow,iveco say there are key switches to re cal but i cannot find them but there is a round plug hole behind teco head,any help please. |
| Bazil-S | Dec 19 2016, 07:37 PM Post #2 |
Hi, It should be a black box, in the fuse box area, or even behind the fuse box. This box must be opened and then set those micro switches, according to the rear axle ratio. There is some documentation on our forum, you need to use the search function of the forum, for "rear axle ratio", or similar. |
| Trevskoda | Dec 20 2016, 09:14 PM Post #3 |
Thanks for info will get torch out and go hunting cheers. |
