| Where is thermostat!?; I realy cant find thermostat housing | |
| Tweet Topic Started: Dec 17 2016, 02:47 PM (474 Views) | |
| Graf Von Spee | Dec 17 2016, 02:47 PM Post #1 |
I bought new thermostat and i have read all repair manual i see the picture showing thermostat housing but i cant find it on my engine. Is this a thermostat housing (it was already empty) : -----> Edited by Graf Von Spee, Dec 17 2016, 03:50 PM.
| graysworld | Dec 17 2016, 03:49 PM Post #2 |
At the front of the block on the left as you look at the engine. Follow the hose. Graeme |
| Graf Von Spee | Dec 17 2016, 03:51 PM Post #3 |
I edited post and attached photo. can you check? |
| JackVan | Dec 18 2016, 12:27 PM Post #4 |
That's the thermostat housing for sure. |
| Graf Von Spee | Dec 18 2016, 08:47 PM Post #5 |
Thanks for replays. I changed Thermostat. Cab Heating in these winter times is essential, and i also hope that my fuel consumption will definitely be slightly lower. Cheers. [SOLVED] |
