| Radiator Fan; Fan starts immediately and "work" without stopping | |
| Tweet Topic Started: Dec 18 2016, 08:57 PM (391 Views) | |
| Graf Von Spee | Dec 18 2016, 08:57 PM Post #1 |
Radiator Fan starts immediately (when engine starts) and "work" without stopping. I changed Thermostat yesterday, this is my next mission. Anyone have clue?
| Bazil-S | Dec 19 2016, 07:27 PM Post #2 |
Hi, Down on the radiator in the driver's side, is a thermal switch, it may be defective, or short circuit between wires. |
| Graf Von Spee | Dec 22 2016, 09:16 PM Post #3 |
I'll try that. And i will report the result. Thanks |
| johnr | Dec 23 2016, 09:11 PM Post #4 |
its possible that a previous owner has had a thermostat switch go duff and has then just wired the fan straight to the power supply so its constantly on, or else run through a switch on the dash to control it. |
| Graf Von Spee | Dec 25 2016, 11:08 AM Post #5 |
Thermostat was already removed by previous owner, i installed new one. Mybe that is the case (rewiring fan electric plug). I got no time now, but with first time-free opportunity i will check your suggestion and suggestion from brazil. Thanks |
