- Pages:
- 1
- 2
| Injector cleaning | |
| Tweet Topic Started: Jan 5 2017, 06:55 PM (1,088 Views) | |
| twoakers | May 17 2017, 06:58 AM Post #16 |
Engineer
Hi Graeme - quick question: Are there copper washer seals at the bottom of the nozzles? Or do they simply sell onto the aluminium head? Can't see any copper washers on mine after removing the injectors! Dave |
| twoakers | May 17 2017, 06:21 PM Post #17 |
Engineer
UPDATE All 4 x injectors done on my 49-12 When I got 'em all out and on the bench I was able to test them. All of them were dribbling and most of the holes were carboned up. What really saved the day IMHO was buying new Bosch nozzles from eBay: http://www.ebay.co.uk/itm/282462063070?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Order late on Monday and with me on Wednesday. Easily fitted in my injectors on my 'clean bench' and torqued up to 60nM Testing revealed that they were all more or less spot on calibration.... ....and that nice 'chirp' as they fired off. Nice clean stray and excellent atomisation All fitted back in the engine, heater refitted, coolant refilled and test run. Engine nice and crisp without excessive smoke. Finally, 2 further jobs to finish in the next fews days: 1. Idle speed should be 750rpm (too low) 2. Need to check injection timing Thanks for your help guys. Hope my experiences help others Feel free to PM for for inspiration and advice |
| graysworld | May 17 2017, 08:40 PM Post #18 |
That is god news, sorry I did not reply to the washer question . I have only just seen it. Anyway you have it sorted it seems. Thanks for the update. good information. Have you got a specialist tester for injectors? Graeme |
| mark hadley | May 17 2017, 10:17 PM Post #19 |
I put in the fuel additive cleaner. There was no immediate improvement - but then at such a low concentration it seems dubious that anyone gets an immediate improvement. Anyway, I've now got through 50l of fuel with the additive and its probably made an improvement. I can start the engine with just a flick of the ignition key and it idles reasonably smoothly. I say "probably" because the weather has improved a bit since January. Still smokey and a bit of vibration, but not sure if that's a fault or a feature. I'll still take it to a specialist at some point. |
- Pages:
- 1
- 2
