| No indicators or hazards on my camper conversion; They just stopped working got no indicators or hazards im pretty handy but where to start ' has any one had this problem ' | |
| Tweet Topic Started: May 31 2017, 02:01 PM (295 Views) | |
| deeley | May 31 2017, 02:01 PM Post #1 |
They just stopped working rite bugger was 140 miles away Has any one had this and best place to start |
| mark hadley | May 31 2017, 04:07 PM Post #2 |
can you be more specific: first: did everything work at the start of the journey? And now are you saying that no indicators light up,not on the dashboard nor on any part of the vehicle? if the answer to both is yes, then maybe fuse, though I can't remember if it is the same fuse for both sides or not. |
| JackVan | Jun 1 2017, 10:29 AM Post #3 |
Another place to look is the hazard switch, there should be a permanent live there. I think I'm right in saying indicators run through the switch (although I'm basing that on Mini's which have the same style of switch) and often are the culprit. You may be able to take it apart and clean the contacts or "short" the plug to test if the switch is at fault. On ours there are at least two fuses one for the hazards and another one (or two?) for indicators, however, the indicator wiring has very obviously been played around with and a new permanent live run to the hazard switch (something to do with the bus conversion). |
| graysworld | Jun 1 2017, 11:28 AM Post #4 |
Sounds like the Relay Graeme |
| deeley | Jun 2 2017, 05:54 AM Post #5 |
Im thinking ive found problem the relay is fitted on small harness put to back of fuse board its up side down and full of water so have sourced new one and waiting to see if will do trick Thanks |
