WANTED: Rear Axle 59-12 Twin Wheel 6.5T 1995
Topic Started: May 31 2017, 08:26 PM (528 Views)
Steveh2108
Guys. Can you help source the right axle for my 59-12 please? Already been burned witn wrong rear axle and wrong, brand new, front calipers.
rrdoctoruk
i have a twin wheel axle from a 3.5 ton if thats any help
Ivotripper
I have just acquired one of these vans which I will be breaking. Unfortunately I am away from home till early August. If you can wait it would be available mid August. I live in west Yorkshire.
Cheers
Richard
Steveh2108
Thanks guys. The truck is 6.5ton. Located an axle now in the free ads. Having it fitted this weekend.
Trevskoda
Make sure you get the right gearing as mine came with a 8/41 which was only good for 45mph.
What you want for a good all round is a 11/43 which at 56 mph will be 2500rpm and 60mph will be around 2800rpm,this will leave first gear a bit low which is good for very steep hills and top just slightly over geared and at 70mph will not go any faster but just above the green band on rev counter.
Im running a ex lib bus on a 59 e 12 alloy g/fibre body at 6.3 ton.
I have not tried a 10/41 so cant comment but it seems to be a common diff ratio ,expect to pay between £250 to £400 for a heavy duty axle complete with hubs etc.
trance
Steve,
How did you get on with the rear axle?
What ratio did you get?
Can I ask how much it cost to have it fitted and how long it took?
Cheers
marcjagman
I have a twin wheel axle for sale if anyone needs one. All I can say is that at 60mph the engine is doing about 2500 rpm
trance
P.M sent
