i've got a clunking sound underneath.; I;ve got a clunking sound underneath, it's a constant but only when at cruising speed, sound goes when you throttle off.
Topic Started: Jun 7 2017, 02:08 PM (469 Views)
ellietheelephant
The vehicle is an Iveco 4x4 motorhome 1991, I've got a clunking sound underneath, it's constant being it does not change with engine speed it's only heard when at cruising speed, the sound goes when you throttle off, any help would be greatly appreciated, regards David.
marcustuck
I would check the universal joints on the prop-shaft, see if there is any play. After that look at the transfer gearbox mountings and after that the differential (rear as I guess its happening when in two wheel drive).
