Vibration at 2000 rpm; Vibration at 2000 rpm appear to be at the rear
Topic Started: Jun 24 2017, 11:47 AM (359 Views)
concept
Hi guys.
I have a 1994 2.5 TD 35/12 camper. I am now getting excessive vibration at about 2000rpm. I wondering if it's the prop shaft centre bearing but can't get under to check at the moment. It's the anything else it might be? It's the same in any gear, and worse when pulling hard!!!
Cheers Trevor
graysworld
I would check wheel bearings too. Is the vibration only when driving? What if you rev in neutral?
Graeme
mark hadley
If it is related to road speed then look at anything after the gearbox.
If it is with engine revs then anything before the gearbox.
Do what Grahame says.1) Rev the engine when stationary and 2) let it cruise at speed with the clutch depressed.
