| 49-10 rear axle; Change rear Axel | |
| Tweet Topic Started: Aug 14 2017, 11:52 AM (545 Views) | |
| Greenmotors | Aug 14 2017, 11:52 AM Post #1 |
Hello, I have owned a 1997 49-10 welfare bus for about 4 years now and have being slowly converting it to a camper. It has had some hidden issues which i have managed to sort but the main one is how slow it is. I have had been reading in the forum that i am not the only one with this problom and i am aware it is a rear axle gear ratio issue. Can i ask a few questions to see if other people have fixed this problom. 1. From reading other posts it seams i have a rear axle with a ratio R = 1:5,22 Z=9/47 (part no.7173881), can i buy the Crown and Pinion gears anywhere and forget about sourcing a complete axle? 2. I live in Ireland and very few of the old Iveco are over here being broke, what model of Iveco should i be targeting with the hope of finding the correct axle that can bolt up to my bus? 3. If i can change out the Crown and Pinion gears what price am i looking at for the components? And last question, is there another way of keeping my hearing above 40MPH and going around 60MPH? |
| trance | Aug 14 2017, 06:35 PM Post #2 |
PM sent Richard |
| mark hadley | Aug 15 2017, 03:24 PM Post #3 |
There are a number of methods to deaden the sound. None is a miracle cure, but they a ll help: See my blog http://drmarkstardis.blogspot.co.uk/2011/04/sound-insulation.html I have bigger tires, but I still cruise at 50mph (less than 2500 revs) mainly because of the dramatic increase in fuel consumption. |
| Greenmotors | Aug 15 2017, 09:03 PM Post #4 |
Very interesting site Mark. Yes I will try the sound deadening, I used it on a landrover and it also made a noticeable difference. I do need a bit more speed though so I will have to change out the diff I fear. |
| trance | Aug 20 2017, 09:55 AM Post #5 |
Any pics of the campervan Richard? Marcjagman could possibly have an axle for sale if your interested? Edited by trance, Aug 20 2017, 09:56 AM.
| Greenmotors | Aug 20 2017, 05:12 PM Post #6 |
Yes I would be interested in the Axel, think its the way to go. I am working on getting pictures up somehow.
Edited by Greenmotors, Aug 21 2017, 06:38 PM.
| Greenmotors | Aug 21 2017, 06:42 PM Post #7 |
Here is another picture, I have still to install a panel over the seating area. This will contain the solar panel and pneumatic cylinder controls. Not too far off finishing it now. |
| Spooky_b329 | Aug 22 2017, 05:53 AM Post #8 |
Lots of the buses will be fitted with that ratio diff, look for panel van/luton vans of the same weight (especially the more powerful versions) to find a diff better suited to cruising. |
