Daily no start-warning lights on.
Topic Started: Oct 4 2017, 09:15 PM (273 Views)
PhilipK
Hi, i'm having problems with a Daily, it does not start, starter swings engine but nothing else.
The icon (yellow padlock) on the instrument cluster stays on, this indicates that the system does not recognise the key, I tried the spare key without any success. In the manual there is a procedure to follow to start the vehicle by entering the electronic code if the system does not recognise the key, you are suppose to use the accelerator pedal while watching the EDC light flashing, I am unable to do this as the EDC light stays on and does not flash.
It seems that the computer thinks the engine is running because on the display it gives the following warnings: Check engine- excessive radiator fluid temp-stop engine-abs not available. That while the engine is stone cold and not running, obviously not running because it cannot start! Something else that is strange is that when the ignition is switched on the oil warning light lights up but then goes out as if the engine started!
Is there anybody with some advice as to what the possible problem could be? Any info or tips would be welcome, thank you.
