2005 eurocargo tector non start
Topic Started: Dec 19 2017, 08:18 PM (1,517 Views)
m_mark
hi all any ideas,have blink codes 6.3 for crank sensor and 6.3 immobilizer???? have swapped crank sensor,turns over but wont fire
m_mark
no fuel at injectors if i crack the pipes so i presume fuel is shut off?? should there be a key sybol on dash if immob is faulty?
cheers all
Ivemech
Do you get a key symbol on the dash? If so the immobiliser doesent like the key/there's is a problem with the key/sensor.
m_mark
no key light on dash,it started ran for about 30 seconds then switched off as if ignition was switched off,only codes are 6.3 crank sensor and 7.2 immob?
aidan
Hi
Serial data would be much more helpful than blink codes which can be misleading on Iveco
Failing that for starters, measure the rail pressure at the sensor when cranking with a DVM, should be 0.5 v key on not cranking and rise to 1.2v min when cranking. I think from Emory it is the middle terminal, but easy to work out as other terminals should be 5v fixed and leas than 0.2v
Aidan
m_mark
ok cheers il have a look,not getting any connection to engine ecu through the diag port,can access everything else though,would voltage at fuel rail indicate ecu and immob powering up ok?
thanks again!
aidan
It would be a good indicator but ECU will have more than one power feed so suppose it is possible that it would only be partly powered, clearly if no voltage you deffo have an issue.
That said you say you are getting blink codes so presumably it has power
m_mark
ok thanks,no fuel pressure at the fuel rail,struggling to find anyone locally who know ivecos well! annoying no cooms with ecu only blink codes
aidan
hi
What are you trying ti read it with ? Where about are you ?
Aidan
Edited by aidan, Dec 24 2017, 03:41 PM.
m_mark
have delphi and blue point scanner can connect to abs etc etc but not eng ecu,based in northamptonshire
aidan
Hi
I guess that's a Delphi clone ?
Bit surprised there is no one in the Northampton area that can deal competently with an Iveco
Aidan
m_mark
no one seems to know or want to look! need someone who know these
Ivemech
Take the pipe off the back of the injector pump (not the one that goes to the engine ecu). Crank the engine over and you should get fuel pissing out the pump. If that is ok connect the pipe back up and unplug the regulator. Try and start again. If it does it will rattle and knock. When you try and start does it smoke?
Whereabouts in Northamptonshire are you?
Edited by Ivemech, Dec 26 2017, 11:15 PM.
m_mark
im not far from thrapston no smoke when turning over
m_mark
fires up with some easy start but wont continue to run,di you have a pic of which pipe? is it the feed pipe to pump? whers the reg too?
cheers again much appreciated!
Go to Next Page
