2007 Box Rear Brake Caliper Assembly; How the hell do I pu tit back together?
Topic Started: Jan 21 2018, 01:43 AM (151 Views)
Guernsey
OK, so rear ABS weren't working so replaced the sensors but also noticed a few problems (different on each side) with the assembly. When we stripped one side the (excuse my ignorant terminology) nut (which is an allen key, with a small ring seal on it which holds the cylinder in) fell out so the cylinder itself came out from the caliper housing. We have been trying to reassemble the bolt which ha this allen key head, basically can't seem to get the thing back together after separating it all down to it's separate nuts and bolts. There are a couple of split washers which need to be in the right place and seem impossible to reset. If you can understand what I@m on about please help!
