Key Code; Key code light flashes hot start
Topic Started: May 4 2010, 05:55 PM (2,219 Views)
rob.bollard
Hi
I have a x plated s29L11
The van runs fine and starts first time every time from cold. Once the engine is hot it will not restart until it has cooled back down again and the key code light flashes.
I have tried by passing with the overide code and pressing the accelerator but nothing.
Have concluded its an issue with the fuel cut off imobiliser sticking.
Has anyone else encountered and hopefully overcome the same problem?
I believe the imobiliser can be removed but it does require a bit of violence on the pump! Cant find anyone who will touch the problem, even Iveco dealer (Northampton) didnt want to know.
Any advice would be much appreciated.
Regards
Rob
hope this helps
this can be done .
you have to remove the controller on top of the fuel pump
this CAN be done in place (have done several) with a bit of care
the put the centre cable to the fuel pump solenoid which is left on the pump.
