| daily 2.8td 2002 starting problem; only starts with easy start | |
| Tweet Topic Started: Jul 5 2011, 12:32 PM (3,166 Views) | |
| eurozulu | Jul 5 2011, 12:32 PM Post #1 |
Hi, Has anyone had this problem at all 2002 2.8 TD, will only start when i use easy start. I suspect low fuel pressure .I have removed the spill pipes for the tops of the injectors and blocked the return pipe.and thought it would show faulty injector ,but no joy.It seems to be pumping fuel OK low pressure pump appears to working OK.The only other item that i have noticed is the red injector light comes on flashes if i hold it in gear and rev above 2.5 then come off the accelerator pedal it comes on but when revs die down 1.5 it goes out it's been like it since i got it 4 years ago. any help would be much appreciated. i suspect fuel pressure switch
Edited by eurozulu, Jul 5 2011, 12:34 PM.
| eurozulu | Jul 15 2011, 06:09 PM Post #2 |
Solved it, the mechanic i had to do leak off test did not know what he was doing,did leak off test today and all four are US.1 with 30mill one with 70mill one with 80 mill and one with 100mill in less than one minute. |
| ehis1 | Oct 13 2011, 07:10 AM Post #3 |
hi am having similar problem with my iveco daily 2.8 turbo engine but only happens when truck is been driven for sometimes and will only start with easy starts ,starts alright when cold and also showing the injector warning light on dashboard pls can you explain to me what a leak off text is and what did you have to change to solve this problem |
