| 40 10 4x4 Tachograph not working; Needle round to 140kmh rhs red light on | |
| Tweet Topic Started: Jul 23 2011, 05:22 PM (1,879 Views) | |
| martin lloyd | Jul 23 2011, 05:22 PM Post #1 |
Hi, hope someone can help. 1993 40 10 4x4. Tachograph reads 140, right hand side (overspeed) red light on, have checked wring can find no poor connections etc Anybody got any idears? Thanks Martin. |
| fraser | Jul 26 2011, 04:36 PM Post #2 |
Hi Does the mileometer work when you drive the vehicle? If so open the tacho, look at the top stylus of the three and see if it is right at the top of slot. If it is make sure you have a chart in the second driver position (Under the black flap) and one in the driver position. Drive the vehicle and the tacho should reset itself and start to work. Hope that helps Fraser |
| martin lloyd | Jul 28 2011, 11:53 AM Post #3 |
Hi Fraser, Thanks for your response, I have put a chart into the unit, and it has started working, so all sorted, regards Martin. |
