| Instrument Cluster; Instrument cluster dials not working | |
| Tweet Topic Started: Aug 9 2011, 06:29 PM (4,273 Views) | |
| zemmelpops | Aug 9 2011, 06:29 PM Post #1 |
Help please the instrument cluster on my iveco 35s12 unijet 2.3 has stopped working. The van starts and runs but the fuel gauge, temp gauge, Rev Counter and speedo plus a lot of the warning lights don't work. The code light works, the indicator, headlight, battery, oil parking brake warning lights and the EDC failure light comes on the goes out as normal. The van did this once before and I removed the cluster and refitted and it worked fine, then it stopped working again the other day then suddenly started working again, and has now stopped completely. I am now have no idea what to try next, help please. |
| Allan | Aug 29 2011, 11:00 AM Post #2 |
old thread, i know, so did you get this fixed? if so what were the steps to fixing it, if not: start with the obvious question, have you verified ALL the fuses that serve the cluster, there are (at least, im going from memory here, so there could be more) 3 to check. |
