Hard to start when hot?
Topic Started: Aug 28 2011, 07:42 PM (3,886 Views)
mike84
Hi, My 2003 iveco 35s12 will start beautifully when cold. After warming up the injector light starts flashing, the rev counter drops to zero and if I turn it off it's almost impossible to start.
I have changed the camshaft sensor ( I thought IT was the problem) but no joy, Any ideas?
Always the rev counter function is linked to the crankshaft sensor, the sensor is defective.
mike84
Tanks Brazil-s
CRANKSHAFT sensor ? not camshaft sensor???
eurozulu
Yes Brazil is correct crankshaft sensor when it is hot it is breaking down and when it is cold will work fine for a while.
mike84
Thanks. eurozulu and Brazil S
Where do I find it? Have looked and can't see it anywhere, I need to check what it looks like so I can order new one.
eurozulu
As you look at the engine it's on the left behind the turbo 10mm bolt you can't see it just feel around .and the wire runs around the back of the block into a plug on the right near the top . on the 2.8 TD it's the same part number as camshaft sensor
mike84
eurozulu
Sep 3 2011, 06:51 AM
Thanks, Will have a look....therefore both sensors are interchangeable???
eurozulu
Yes as i stated i know on 2.8td they are the same so can be swapped.
mike84
Hi Eurozulu,
Mine is a 03 reg 35S12....it's a 2.9 turbo diesel unijet
.Can't find that sensor where you say?
If you can not find the sensor, where eurozulu has told you, means that the engine is 2.3l and the sensor is under high pressure pump (red connector).
mike84
Sep 4 2011, 04:55 PM
Yeah you're right....and all the time I thought I was driving a 2.9 :$
Will look tomorrow, Thanks
mike84
Changed the CRANKshaft sensor, (underneath the pump on right hand side) and all going well now.
Thanks folks. Appreciated.
Both sensors are Not transferrable on the 2.3
Camshaft sensor about 25mm 1 inch long.
Crankshaft sensor 40 mm 1 1/2 inch long.
