| iveco daily fan; van cuts out | |
| Tweet Topic Started: Sep 2 2011, 06:58 PM (8,968 Views) | |
| kardking | Sep 2 2011, 06:58 PM Post #1 |
hi guys im a newbie here ,the radiator fan has stopped working and the injector light flashes ,then when the vans gets hot it cuts out.ive priced a new engine cooler motor up and very expensive .ive found one from a scrapyard but my model is a 2003 and the other one is 2001 . does anyone know will it fit in my van. iveco daily 35s12v p/v,2.300.thank you. |
| mike84 | Sep 5 2011, 06:19 AM Post #2 |
Jul 30 2011, 10:18 PM Post #3 Member Avatar Administrator [ * * ] Posts: 273 Group: Admin Member #1 Joined: November 22, 2009 SPOOKY I had this problem, turned out the fan just doesn't turn on until the gauge almost touched the red! I has checked loads of stuff and replaced the temp sender before I let it get hot enough to activate the fan. If you undo the connector behind the fan and apply 12v you should hear a loud click, this is the electromagnetic clutch engaging... If the engine is running this will cause the fan to spin up. |
| mike84 | Sep 5 2011, 06:21 AM Post #3 |
Bazil-S Jul 30 2011, 10:33 AM Post #2 Member Avatar Member [ * * ] Posts: 293 Group: Resident Expert Member #195 Joined: June 7, 2010 Hi, The fan is activated at over 96oC and deactivated at under 84oC. Often the fan is not to blame that the engine heats up too much, but you can check.. Electromagnetic (fan) coupling is powered by fuse number 5, the relay no. 25336 (see fuse box and relays diagram), then connects with the engine harness thru the connector 72030 (located behind the battery) . Power wires are: the positive: green 8879 code and the negative: brown 0000 code. The engine harness began from the connector 72030 and ends at alternator. You can check the wires with the above code not to be broken, starting from connector (located behind the battery). |
| kardking | Sep 7 2011, 07:05 PM Post #4 |
hi guys thanks for the replys,i didnt change motor on the fan , garage guy said its not electronic, he put it on computer, nothing showed?. anyway he took it for a drive no light came on for him ,he couldnt find the problem,might hav been bad diesel or water..im stumped gonna use it moro for work fingers double crossed. |
| Spooky_b329 | Sep 7 2011, 09:12 PM Post #5 |
Hi, if it is a fan problem causing the overheating, the van will only overheat in heavy traffic or when driving slowly in 1st or 2nd gear. At higher speeds the fan is redundant as air coming through the grill will cool the radiator. As quoted above, the fan is driven via the auxiliary belt, and engages/disengages via an electromagnet. You should see a couple of wires leading to the fan, and a connector. Unplug the connector and apply 12v and you should hear a clunk, if you do this whilst the engine is running the fan will start. On my van I cut off a redundant connector that was strapped up to the loom near the wiper linkage so that I plug it into the fan wiring and wire it to turn the fan on manually, the engine gets quite near the red when I am towing a heavy trailer at low speeds. I only did this as I thought the temp sensor was faulty. |
| kardking | Sep 8 2011, 02:36 PM Post #6 |
anyway thanks spooky for u reply , drove the van today for about 20 miles perfect ,gonna have service on monday to clear cobwebs,yours confused. |
| kardking | Sep 11 2011, 08:07 AM Post #7 |
sat10/11/11, van broke today after 3 days of use. flashing injector light engine cuts out , back to square1 .so if its not electrical how can the mechanic know what it is ,dam iveco
| kardking | Sep 12 2011, 07:29 PM Post #8 |
turns out the disel pump is knackered |
| gazzab1978 | Sep 16 2011, 05:08 PM Post #9 |
which diesel pump is gone, the low pressure lift pump or the high pressure injection pump. if its the high pressure pump i have a spare you can have cheap |
| kardking | Sep 19 2011, 09:13 PM Post #10 |
gazza, it was the low pressure pump.thank you anyway,garage done the pump and service for £360, its like driving a new van
