| Rear Seats; seats in rear and midway bulkhead | |
| Tweet Topic Started: Sep 5 2011, 09:38 AM (983 Views) | |
| Bazzyt23 | Sep 5 2011, 09:38 AM Post #1 |
Hi Folks I have a 35s9 mwb and would like 2 put some seats in rear. Van floor is ply lined. So are there any holes etc in the floor suitable for mounting seats (with enforcement of course) before i start lifting the plywood. Also anyone put a bulkhead in midway down the back ie just past the side door ? Thanx Baz |
| mfoobar | Sep 10 2011, 09:15 PM Post #2 |
I'm not sure if there are any factory mounting points or not, but I put some minibus seats from an LDV in the back of mine (a camper conversion 35S11 MWB). The reason I went for the LDV ones in this case was they were very compact and they had both seatbelts integral to the seat (not one attached to a wall). I just bolted through the floor and put steel bars underneath to bolt through and spread the load. -Matt |
| Bazzyt23 | Sep 11 2011, 12:44 PM Post #3 |
Ta. what size of bar did you use ? I picked up a (full) set of vw transporter seats yesterday so I can mix and match three for the back. Has anyone put a bulkhead in behind a second row of seats ? I was thinking inch angle iron and ply ???? |
