| Difficulty starting hot or cold | |
| Tweet Topic Started: Sep 7 2011, 06:20 AM (884 Views) | |
| morne | Sep 7 2011, 06:20 AM Post #1 |
Still a problem starting without Quick-start. I get no reading at the thermo start solenoid valve or glow plug with the ignition on or when starting. Diesel feeds to the solenoid valve but not from there to the glow plug. Is the thermo start not supposed to do what we do with quick start? And is this only activated when the air temp is under 10 deg. Cell. I am in South Africa and it is currently 27 deg. I can see what the temp is going to be tomorrow morning and if under 10, I can check if voltage is fed to one or both of them. Can one manipulate the map so that the thermo start is activated at all temperatures and will this help with the starting. |
