| Removing parcel shelf | |
| Tweet Topic Started: Sep 11 2011, 07:19 PM (1,253 Views) | |
| mfoobar | Sep 11 2011, 07:19 PM Post #1 |
Hi all, I have a converted Iveco Daily camper (35S11 MWV H2 roof, 2000) and am considering removing the parcel shelf above the cab to make way for a drop down bed. The bulkhead is already removed. Is it an easy job to remove the parcel shelf? Is it just bolted in, or is it welded? Mine is currently all covered in carpet so I can't check. I'll also have to remove the headlining from the cab ceiling and the tops of the seatbelt pillar plastics. Do you know if Iveco ever did a daily without the parcel shelf, ie are the part numbers for headlining that goes all the way up to the top (ie so the cab area is full height without the parcel shelf there) if I wanted to replace the headlining with factory one? -Matt |
