| no dip beam; headlights | |
| Tweet Topic Started: Oct 1 2011, 09:42 PM (1,458 Views) | |
| floroworld | Oct 1 2011, 09:42 PM Post #1 |
hi got no dip but got side and main beam did the solder thing ,theres no output on pin 10 on p2 blue plug on stalk unit dose any one know the id off the coulors from headlight stalk(small loom)or any where to check on the unit where P1 and P2 plug in 35s11 year 2000 cheers flo |
| Bazil-S | Oct 2 2011, 10:17 AM Post #2 |
Hi, Check the voltage on pin No. 8 (+15 = positive with ignition on - white wire code 2201) from the stalk unit at the P2 connector, if it is not then check the fuse No. 7 (10A). The fuse No.7 is for low beam before the stalk unit, sort of main fuse for low beam. Check the pin No. 8 if it`s not weakened, or burned. |
