| Dimmer Switch Operation | |
| Tweet Topic Started: Oct 5 2011, 01:37 PM (1,413 Views) | |
| mlonghurst | Oct 5 2011, 01:37 PM Post #1 |
Please excuse such a dumb question, I have a 2004 Iveco Daily 35S12 and seem to have lost my dash lights. Have discovered the dimmer switch but not sure if this is simply a push button or push and turn or just turn to get the light bright again, which is it? It may also just be a fuse blown or worse a wire problem. Rgds, Mike L |
| ivycoil | Oct 5 2011, 08:55 PM Post #2 |
Baffled me for a bit as well - press and hold the switch, it cycles from dim to bright. I think the minimum setting still illuminates the dash slightly, so if you've no light at all it could be more than just the setting. |
| mlonghurst | Oct 7 2011, 04:10 PM Post #3 |
Thanks for that, I will try it tonight and prey it works :-) |
