| Horn has stopped working | |
| Tweet Topic Started: Oct 7 2011, 11:28 AM (1,919 Views) | |
| GARY F | Oct 7 2011, 11:28 AM Post #1 |
Hi, My horn has stopped working and wondered if anyone has had this problem? Basically before it packed up all together, sometimes it used to sound as if it was dying, like sort of stuttering. Then eventually just stopped working at all. I've checked fuses and the plastic casing in the steering column, but no joy. Anyone have any ideas? Cheers, Gary. |
| windyjools | Oct 11 2011, 03:22 PM Post #2 |
I had the same problem, after dismantling the horns and cleaning the earth connection, it turned out to be the multi-pin connector on the steering column, it just clicked back into place and all was well, not apparent from a quick look, but it solved it for me, also check the earth connection, this can give the same sort of indication. |
| gazzab1978 | Oct 11 2011, 04:00 PM Post #3 |
mine does it too, just the terminals on the horn coming loose on mine, push um back on job done |
| Spooky_b329 | Oct 11 2011, 06:15 PM Post #4 |
Horn is bolted to the air filter bracket, take a look at the connections. |
