| 35s12 wont start injector light and code light flashing!!!! | |
| Tweet Topic Started: Oct 13 2011, 07:38 AM (2,163 Views) | |
| blade | Oct 13 2011, 07:38 AM Post #1 |
i have a 35s12 55 reg and about 2 weeks ago it just stop as i reversed it and the injector light flashed cut a long story short had same prob with another van a year gone by and it was the low pressure pump so i changed it on this van and it has run a dream and done 4k till yesterday my friend went to start it and the injector light started flashing then the yellow code light???? he had to be towed on a ferry yesterday and gets off in plymouth today has anyone any ideas??? or is it best to book in with iveco??? thanks stu. |
| sudden | Oct 14 2011, 04:21 AM Post #2 |
Just an idea have you checkt the batteri.If the voltage dropps under 10.5 v when you turn the starting key you can get this problem.So carge the battery and give it a try.And dont use a power pac to start the van you can burn the ECU. Sorry for my bad English.
