| WTF! headlights now working.. | |
| Tweet Topic Started: Oct 14 2011, 08:31 PM (969 Views) | |
| wezza | Oct 14 2011, 08:31 PM Post #1 |
Bought a new switch column from a breaker as I tried the solder fix, which only worked for 2 days so I returned to having side lights and main beam, no dipped lights. Changed over the switch column and the headlights now work, however the indicators flash on constantly like the warning lights when the engine is turned over. The indicator stork is in the off position (Central), when I opened up the switch assembly, the little copper mechanism is clicking away non stop. Anyone got any clues as to what is going on please? Regards, Wez |
