| 195x 75xr16 tyres for 50C18 | |
| Tweet Topic Started: Dec 11 2011, 09:02 AM (1,893 Views) | |
| Ozveco | Dec 11 2011, 09:02 AM Post #1 |
Hi, Anyone here in Oz sourced replacement tyres for a 2009 50C18 dual cab ? I will need to replace the fronts soon and was wondering what brands out there have this size ? So far choice seems to be limited and expensive. It's a pity the wheels are not 17 1/2" where there is plenty of choice at reasonable cost.
Edited by Ozveco, Dec 11 2011, 09:03 AM.
| frankm | Dec 25 2012, 12:03 AM Post #2 |
Hi there, I have the same vehicle - also in Auz. They have plough-disc 5" rims which limit what you can do, but I went to 205 75 16 tyres. They fit OK, and exceed the original load specs. Being bigger you can run a few pounds less and smooth out the ride. Also they go a little way toward correcting the speedo. I have used a few brands that are reasonably priced including Weslake and Yokohama, but I believe the best of these was a Uniroyal Rainmax. They have got a solid tread for stones and they wear evenly. I can't wear a Michelin or Continental out as they usually sacrifice themselves on a rock, and the Yoky's are good , but a bit fast wearing. I'm in my 8th year of driving Daily's and am still searching for a 6" or 6'5" rim for the front, but no luck yet. Cheers, Frank. |
| Ozveco | Dec 27 2012, 07:46 AM Post #3 |
Thanks Frank. I have seen mags advertised in the UK but nothing here in Oz. John Frank, the new 70c17 has 6"rims Edited by Ozveco, Dec 27 2012, 08:19 AM.
| Ozveco | Dec 28 2012, 08:50 AM Post #4 |
Hi Frank, who is the distributor of Uniroyal Tyres in Australia ? I have had no luck using internet search engines John |
| MrDaily | Dec 29 2012, 12:47 AM Post #5 |
Hi John Try bob Jane T-mart Www.Bobjane.com.au Another brand to consider is hankook Cheers |
