Belt driven engine in a 4x4; Is this ok?
Topic Started: Dec 22 2011, 12:41 PM (1,824 Views)
gerryoxford
Can you change the main seal by removing the gear box, or does the engine have to come out.
Thanks
Edited by gerryoxford, Dec 23 2011, 02:45 PM.
Motormedic
To be honest there are many possibilities when it comes to oil leaks,the best way is to power wash the motor and underside and locate were it is coming from then decide your action.
MM
eilish
Can anyone tell me if there is a timing belt or chain in a 1998 IVECO DAILY CAMPERVAN or how i can tell. thanks
dorset tony
The chain drive engine was fitted to the 4x4 version.The belt has a plastic cover whereas the chain is oil lubricated and therefore is in a steel casing.
Tony
ashman11
it has a belt on the Gen 3 4x4 too i think, well mine does anyway.
richc-101
to my knowledge there wasn't a 3rd generation 4x4
The current (4th gen) 4x4 is not actually an Iveco at all really but built by a company called Scam (yes really) using Iveco parts.
You can buy a Scam and its the same vehicle but it uses a Ducato Cab
http://www.scamtrucks.it/azienda/chi-siamo_en
oh and to answer the origional qustion yes a belt driven engine can be put in a 4x4 daily, but with the plastic cover etc i'd be nervous about wading and alot of sand
