Where is engine number?
Topic Started: Jan 4 2012, 01:18 PM (7,357 Views)
KnightDrifter
Hi guys,
I need to order an engine part for a 2001 Iveco Daily 45c20 (iirc) however cannot find the engine number!
Since the van has had a new engine put in last year, I'm unable to use the vin plate to find which engine I have.
Does anyone know where on the block the engine number is located?!
Thanks for your time.
russ hesketh-roberts
I had this problem last month. The number is a bit*h to find! It's stamped on the block behind the turbo, I could only see a couple of digits of it!
There should also be a barcoded sticker on the timing belt cover and the plastic cover over the rocker cover(with egr vlave fitted) In several places on this sticker will be a seven digit number. On mine it's Printed twice along the top of the top barcodes. I'll try and put a picture on tomorrow if you like.
Russ
KnightDrifter
I'll check that tomorrow, thanks Russ!
