IVECO STRALIS EDC 2F fault code; IVECO STRALIS EDC 2F fault code (engine cant start)
Topic Started: Mar 23 2012, 09:54 PM (33,084 Views)
zoki
I have Iveco Stralis and when i was driving EDC 2F code was lighting on the computer then the truck lose the power and the engine turned off. I change the fuel filter and pupm but the engine didnt start again i still have this problem and i dont know what to do. PLEASE HELP!!
Derbywill
Did you bleed the fuel system up? theres a bleed nipple on each fillter head and one on the front of the cylindr head
EDC 2F is turbo underspeed detection, theres a valve and sensor that controls the turbo on Cursor 10 and 13 its located under the thermostat housing and on cursor 8 its on the block under the turbo.
ideally it wants a turbo test doing on easy to se what is happening but you could try replacing the sensor on the control block its about 30 i think
Will
mkampstra
First be sure all air has been bleeded out like Will Derby told you.
Check electrical airvalve, and check pneumatic valve on turbo. Also check turning point on this valve on turbo.. Every sticking can provide this fault...
Iveco dealer has special test on diagnose computer to see where turbo sticks
mycollins22@yahoo.com
Sir,
one of our Euro 5 stalis has these fault codes of which when the codes diplays, the truck's movement will retard and will eventualy stop.
please can any one help me
ECM 99 (yellow colour)
ECM (yellow colour)
ECM A5 (yellow colour)
CRS FAULTY (red colour)
Odeh Collins
From Golden Transport Nigeria Ltd.
ALL-HI-WAY
Jun 5 2015, 07:03 AM
Sir,
ECM (yellow colour)
Odeh Collins
hy
The ECM99 is a defect appears when the turbocharging have mecanicaly internal deffect, but please vetify if yow dont have ploblems on fuel sistem filter blocked or the ful heater.
ALL-HI-WAY
Jun 10 2015, 05:41 PM
Sir,
ECM (yellow colour)
Odeh Collins
hy
Hellow Engineer,
the turbo has been completly replace and i am corrently checking the feul heater and fuel systems
but please what is the way out of SCR Fault code.
Collins''
Jun 15 2015, 10:38 AM
ALL-HI-WAY
Sir,
ECM (yellow colour)
Odeh Collins
hy
Hellow Engineer,
Collins''
Hello Friends,
I have EURO 3 Iveco Stralis displaying "EUROTRONIC FAULT 9A" after displaying this, the gears will not engage again
can any friend be of good help?
Collins''
Hello Friends,
Can any one be of good help for the meanings of the Stralis codes;
1. Hgv fitter
2. DTC
3. FMI
4. OC
5. ACT
Collins''
Edited by mycollins22@yahoo.com, Jun 16 2015, 10:59 AM.
hgvcourses
I have the same problem..
EDC 2f code when pulling up a gradient. Truck feels sluggish!
DealsFor.me - The best sales, coupons, and discounts for you
