Speedo not working; TDaily 2.8 W2000 plate 1998 body speedo fault
Topic Started: Mar 26 2012, 12:21 PM (51,744 Views)
Possible the needle mechanism to be be half stiffened, so open the speedo and clean the mechanism with isopropyl alcohol.
Ralphg
I've just taken my speedo apart & cleaned it. Let's hope that it has fixed it.
Whilst taking it apart I googled Veglia Borletti speedometer. They were also used by Ferrari in the early '80s. They seem to suffer from a very similar problem, not reading above 55mph.
Ralphg
Well, my speedo now works! It is now reading 3mph too high, but that's because I didn't put the needle back on in exactly the right place.
Thanks Bazil-S for the suggestion.
Tokarevserg
mark hadley
Jun 21 2015, 04:33 PM
Hi, I have a manual, six pages with dip switch settings for 8 switches.
I don't know how to do attachments here so send me your email and I'll send it to you. Its a 2MB pdf file.
If anyone has a 10 switch box available then I'd be most interested because with my large tyres and 8 DIP switches I can't it still under reads.
30022167@mail.ru дай схему пожалуйсто!
Tokarevserg
Tokarevserg
Feb 13 2017, 03:49 PM
mark hadley
Hi, I have a manual, six pages with dip switch settings for 8 switches.<br />I don't know how to do attachments here so send me your email and I'll send it to you. Its a 2MB pdf file.<br /><br />If anyone has a 10 switch box available then I'd be most interested because with my large tyres and 8 DIP switches I can't it still under reads.
Tokarevserg
mark hadley
Edited by Tokarevserg, Feb 15 2017, 04:40 PM.
Tokarevserg
Hillyards
Mar 2 2014, 10:41 AM
I also have speedo & rev counter not working and I'm trying to work through the above advice ; however my set up appears to be different.<br />i have yellow 3336 connected at battery teminal and i have the adaptor above the fuse box.<br /><br />At Sensor : 2A - continuity <br /> 2B - 8v<br /> 2C - nothing<br /> 2D - 6,6v<br /><br />connector A <br />pin 1: 7772 <br />pin 2 : 4444<br />pin 3 : 8879 + 5511<br /> <br />pin 5 : 3336<br />pin 6 : 0000 + 0000<br /><br />connector B pin 3 : 5513<br /><br />Also at connector xx i have this :<br />5558 - continuity<br />5517 - 6,6v<br />5517 - 8v<br />connecting to 5558, 5517,5516;5514<br /><br />Racking my brains on this; if anyone can shed any light on this be much appreciated
Hillyards
2B - 8v
2C - nothing
2D - 6,6v
connector A
pin 1: 7772
pin 2 : 4444
pin 3 : 8879 + 5511
pin 5 : 3336
pin 6 : 0000 + 0000
5558 - continuity
5517 - 6,6v
5517 - 8v
