| Light problems | |
| Tweet Topic Started: Apr 2 2012, 07:49 PM (4,472 Views) | |
| wrshinn | Apr 2 2012, 07:49 PM Post #1 |
After many weeks of endless problems with my iveco daily 35S 13 lights i have finally solved this problem, 1st i lost my rear side lights & dash lights fuses where fine all wiring fine at the rear.....god knows so i took a jack wire from front light to the back lights...... fine for an hour... (even worse than before) so i order a new stalk switch £50!!!!! about to fit new stalk and come across my two yellow power wires where melted together. split them apart, bit of tape.....like brand new.....we have light so share the knowledge as i look to this site step by step of my frustrating task. see images attached of wires.
| mike84 | Apr 5 2012, 09:42 PM Post #2 |
Thanks wrshinn. |
| sparky7 | Sep 13 2012, 10:36 AM Post #3 |
I have same problem, no rear, side or dash lights. Checked wiring on column as per photo all fine. But only difference is it keeps blowing fuses. Works for 15 mins then blows. Had it into a garage which was a waste of time and money. Any advice would be appreciated as I'm in Scotland and it will be getting dark at 1pm here soon lol |
| mike84 | Sep 13 2012, 05:25 PM Post #4 |
Do you have a socket at the back for towing a trailer? Could be damaged and letting in water hense blowing fuses? |
| sparky7 | Sep 14 2012, 06:08 PM Post #5 |
No socket it's been removed tow bar still there. Thanks |
