| fitting bigger anti roll bar | |
| Tweet Topic Started: May 14 2012, 09:44 PM (3,528 Views) | |
| damien roe | May 14 2012, 09:44 PM Post #1 |
hello again guy's i have a question is the antiroll bar on the 50c vans thicker than the 45c van thanks damien |
| damien roe | Sep 17 2012, 11:53 PM Post #2 |
knowone know if the heavier ivecos had a thicker antoroll bar?? |
| Spooky_b329 | Sep 18 2012, 05:54 AM Post #3 |
Sorry, can't answer this although would be interested to know. If you get the reg from a 45 and 50c and call up Iveco/Vexi, they will be able to tell you if its a different part number. Same part number = interchangeable
| damien roe | Sep 18 2012, 08:43 AM Post #4 |
im after a thicker bar i have searched and found a rear anti roll bar and it's brackets from a 65c for £60 my problem is i have a 45c14 minibus and with a full load on board it can be very unsteady (roll'y) so im going to have a go at fitting a bigger bar |
| ivecojoe | Sep 18 2012, 10:06 PM Post #5 |
Hi Before you change anti roll bar I would firstly check the spring bushes,shock absorbers and so on,as I have owned several and havent had any rolling problems,are all the ball joints etc in good condition,if all above are good have the springs gone soft ? you can get them refurbished. Just be aware as carrying passengers obviously carries a lot of responsability and I would think modifying a vehicles suspension maybe frowned upon. as a matter of interest has it got torsion bars on the front or transverse spring, if its spring check the carrier/frame as these have been known to fracture. hope this helps. Paul |
| 4040 | Sep 18 2012, 10:31 PM Post #6 |
I have a 50c14, I will measure it in the morning as I am doing some work to it at the moment |
| damien roe | Sep 19 2012, 02:36 PM Post #7 |
thank you very much mate would any one have a 65c daily just to compair the thickness in the bars Edited by damien roe, Sep 19 2012, 02:38 PM.
| 4040 | Sep 20 2012, 05:03 PM Post #8 |
Hi, sorry for the delay. Mine is 20mm diameter (rear) |
