sliding door opening; door opening on move
Topic Started: Sep 11 2012, 11:40 AM (1,457 Views)
weeme
Hi folks
recent Iveco 35 12s owner.
sliding door is opening while driving.
Any ideas where to start looking for fault?
never dealt with sliding door locks before.
suggestions appreciated
weeme
If the door lines up on the outside and is relatively flush, then just try moving the striker plate on the C pillar. It should latch shut without excessive slamming but should also hold the door as close to the rubber seal as possible. Behind the door card is a metal rod from the handle and there is some length adjustment on this. There is a catch at the top of the C pillar too that can be troublesome but I would ignore this until the main catch is sorted.
There are two studs on the leading edge of the door that locate into plastic lined metal sockets in the B pillar, if these are out of alignment they can also prevent the door shutting properly.
If the door is bent then all bets are off!
Edited by Spooky_b329, Sep 12 2012, 06:58 AM.
weeme
Thanks for prompt reply
I have lubricated the rear catch at the top rear of the door, it was a bit sticky.
top of door is slightly out from body
but not leaking, is this adjustable?
will run for a while and see if the fault comes back
weeme
The top catch is just additional support, mine is missing completely and my door is water tight, but it does rattle a bit. I think the main catch is the cause of your door opening. If the rollers have worn out your door may have dropped so the catch isn't lining up.
mfoobar
...or the length adjustment that spooky mentioned has been done up too tight and maybe going over a bump or something is causing it to release the door. I know when I adjusted mine when it was too loose I first did it too tight and the door wouldn't latch shut.
-Matt
weeme
Thanks for suggestions.
It has not happened again, so fingers crossed
weeme
