+50 for starer; Diagram
Topic Started: Sep 22 2012, 02:42 PM (808 Views)
edaamo
Hello.
I have a Dayli 35s15 with 2,8l. When I got it it hat a start butten for +50 starter. The old wire has burned for some reason earlyer. It started to suddenly be out of power(electrical) when I pulled som in the wiering it was ok again. I have now remowed al the damaged wire from torpedowall to the starter and fixed the damaged parts. I would like to tart the car just by using the key but is shure if the ignition was the reason for the burned wire.
Do anyone have diagram for the ignition?
Also what is wire 8888 pin 18 on connector right side intrument?
Regards Edvard
edaamo
Anybody?? :huh:
Sorry I can't help, hopefully someone will be able to give you some advice.
