35/S/12 engine injection wiring loom needed
Topic Started: Sep 29 2012, 07:12 PM (2,093 Views)
Bazrippa
I have a few questions guys, I have a misfire on all injectors that has been traced back to the injection harness which has been a problem before on this van.
I need to know the part number for it, if anyone has one lying about that i could buy and does anyone know where i might pick one up at the right price??
Iveco want £475 plus VAT give or take a few quid.... ^o)
Sorry the van is a 2003 35/s/12 with the 2.3 HPI engine...
Edited by Bazrippa, Sep 29 2012, 07:18 PM.
ashbyspannerman
have you tried the trick of slightly twisting the pins on the injectors?
it cured my injector problems, the weak point on the injector harness seems to be the connections to the injectors themselves.
mine regularly had injector faults, since slightly twistin the pins it has'nt missed a beat.
Bazrippa
I haven't tried that but i will do it now, the diagnostic shows that it has a multiple injector failure due to a wiring fault..
It had a similar fault not long ago which came down to a broken wire in the harness which ran to the injection pump but i have just had a tester on that wire and continuity is fine, in fact they all are..
What symptoms did your van have that twisting the contacts cured???
Oh and i should add that i have just had a recon injector fitted on monday and the fault showed up on wednesday..
Edited by Bazrippa, Sep 30 2012, 01:05 PM.
Bazrippa
I still have this problem, tried twisting the injector contacts and its a no go.. :'(
Bazrippa
just to wrap this up the problem turned out to be the injector that i had just had reconditioned, it was leaking back..
Cheers..
