| egr; egr 35s14 | |
| Tweet Topic Started: Oct 29 2012, 11:47 AM (1,768 Views) | |
| 1240 | Oct 29 2012, 11:47 AM Post #1 |
hi need help how to remove egr valve from 35s14 fia engine 2.3 |
| mkampstra | Nov 4 2012, 11:15 PM Post #2 |
You wish to remove EGR complete or to change because of a problem? And what part of the EGR you want to remove? |
| 1240 | Dec 27 2012, 09:24 PM Post #3 |
clean the egr valve engine lack power and Engine failure 148 |
| ALL-HI-WAY | Dec 30 2012, 11:23 AM Post #4 |
If the engine is F1A is a litle heavy because you dont heave space over there behind the engine. if you can try from under vehicle . |
| mkampstra | Jan 1 2013, 09:16 PM Post #5 |
EGR is not the problem itself. The fault is about turbo... Most of the times the little electric valve regulating the EGR is leaking. Change that one. It's a little black valve with a connector and two small hoses. It has a white hat. There is another one around it, connected to the turbo. |
