| severe lack of power | |
| Tweet Topic Started: Nov 10 2012, 04:10 AM (1,290 Views) | |
| muzzy225 | Nov 10 2012, 04:10 AM Post #1 |
i have a 56 plate 2007 35s12 2.3hpi on a cold start the engine will start but on pressing the accelerator very little happens. if you leave it running 5 mins and then press accelerator there is more of a response. while driving it really lacks power especially up hill. steep hills is a 1st gear job at 10 mph. motorway hills are generally taken at 40mph. not good. a couple of days ago i had about 5 miles of a normal van, lots of power even uphill, then it went back to low power. the yellow engine light comes on frequently along with the flashing red edc light. sometimes the edc light stays on. i have changed the airflow meter but no difference. gonna take egr valve off today + give it a clean. any advice would be most welcome. thanks |
| Onmaneez | Feb 23 2013, 07:50 AM Post #2 |
Hi muzzy 225, had very similar problem ,after a few quid spent on trying to solve it with no joy.I had a heavy load and the van cut out completly ,turned out to be low pressure fuel pump . |
| aidan | Feb 23 2013, 08:09 AM Post #3 |
Hi You need to get this on a diagnostic / scanner to find the fault code causing the MIL lamps to come on. Little point in wasting time and money on guess work. Sound like the fault is putting it in reduced power (limp home) mode. It does not have to go to dealer, some aftermarket kit will diagnose these. Aidan |
