auto gearbox
Topic Started: Dec 7 2012, 09:44 AM (1,439 Views)
paulss1
i have an iveco daily 2007 35S14 MWB model with a semi auto gearbox, the problem is that when the engine gets hot ( iam assuming this ) the gearbox will not change gears, the red edc light comes on and the yellow geniric triangle lwarning light comes on, if i pull over and stop the fault clears and the gearbox works okay for a while, when the engine is cold the problem is no longer there, the fault code 004 comes up when the gearbox issue happens, any ideas anyone
Dave sp
Dave
Hi, very interesting reading your problem with the 2007 model, mine is the 2006 & apart from the error codes which I haven't noticed on mine am having the same issues. My probs occur after vehicle is hot & can take up to 20 minutes of sitting with engine off to reselect a gear? I can no longer trust this as a work truck & am getting quite desperate dealers aren't much help at this stage, getting very costly, has been going on for years, only done 75,000ks. I wonder if these vehicles are only suited to cold countries? This forum is very helpful. If there were enough of the same problem perhaps a class action is needed :huh: :unsure: Good luck with yours!
