| 1st & 2nd gear issue | |
| Tweet Topic Started: Dec 12 2012, 02:36 AM (2,550 Views) | |
| Supermotodaz | Dec 12 2012, 02:36 AM Post #1 |
Hi Just brought an 2008 35C 15 3.0 ltr, plan on kitting it out for bike racing, got it from a dealer . Having real problems to engage first and second, all others are nice and smooth but first is difficult , second almost impossible, could this be a simple linkage adjustment issue or is it something more serious. Daz |
| ivecoboy | Dec 12 2012, 09:19 PM Post #2 |
is the gear stick lifting up an down with wear take the cover of an look at the plastic ball if it is ok then does the clutch feel ok check the linkage at the gearbox an make sure if someone has had the gearbox out they havent broken of the ends at the gear change an welded them on what milage is on it |
| Supermotodaz | Dec 15 2012, 05:21 AM Post #3 |
Cheer,s for reply, mileage is 95,000, it's going back to dealer today for further investigation, only had it a week so they have agreed to sort it, the other bloody issue which keeps occurring is the EDC wearing light staying on steady, had it reset once ,then came on again and they replaced a relay and reset, now it's come back again, are these sort of issues a common occurrence or am I just being unlucky. |
| The Iron Works | Dec 15 2012, 12:20 PM Post #4 |
I would say unlucky, I have the same model as you and same year with 70k on the clock and the gears are pin perfect and never had faults with edc lights etc. When I looked for one I looked at a van that's still for sale on ebay and he said it had done 60k miles, but it had been clocked. I would have said it had done 160k - 200k miles and the 1st/2nd gear was terrible on that too.... |
| Supermotodaz | Dec 15 2012, 02:06 PM Post #5 |
I done exactley the same looked at one down in Kent that had 42,000, pictures looked good on eBay but van had been through the mill and had definatley done a lot more milage, the one I brought looks mint and the dealer has done anything else that was needed on it so hopefully once these two issues are sorted it will be a good motor. |
| mkampstra | Dec 27 2012, 12:22 PM Post #6 |
Most of the times there is play on the ball under the cover. But you can delay a change of gearstick by adjusting the cable. It's very easy. At the cable which operates sideways you see mounting to the stick, below you see the outsidecable mounting on the base. Between that there is a spring, under that spring is a black adjustment lock. If you put in gear 3 and slide up the lockup you can freely move the stick to left and right. Adjust slightly to the way you want and try again. |
