part code for front cab mounts
Topic Started: Dec 12 2012, 02:33 PM (2,038 Views)
rawcraftwood
Have decided to replace the front cab mounts as per several discussion topics to see it eleviates vibration through steering a a bit of harshness in the cab itself over rough roads, and I was given the part number from the Iveco dealer of 42555621. I put this number into Vexi parts and it came up with a set of dowels? Is this the part I am after ( i would have thought it would be under ' rubber cab mounts' or something similar? ) TIA
stuyg
hi
yep the parts you need are called a set of dowels
when i did mine it didnt change the feel from the steering but it stopped the bang going over bumps
rawcraftwood
Thanks for the reply stuyg, did you happen to end up getting the steering sorted, if so, what did you end up doing?
stuyg
hi changed this bit 42554508 (stick this number in the bay) but could also be upper or lower arm bushes
