| 2007 35s10 Engine doesn't STOP | |
| Tweet Topic Started: Dec 17 2012, 12:33 PM (1,295 Views) | |
| Joep | Dec 17 2012, 12:33 PM Post #1 |
I have a 2007 35s10v (aglle) iveco daily here. The problem is when i turn the iginition off the van doesnt stop the engine. By disconnecting the main fuse i can stall the engine but when i remove the iginition key once i reconnect it the dash doesnt turn off and all the instruments are still functioning. My guess is that the main relay is defective, where is it located? The ignition switch i guess isnt the problem, i disconnected the connector but still the lights are on on the dash. |
| Joep | Dec 17 2012, 06:40 PM Post #2 |
Doesn't seem te be the problem, does anyone have an idea of what the cause of this problem can be. Else i will have to bring it in. |
| Bazil-S | Dec 17 2012, 07:53 PM Post #3 |
Have you recently fitted a new radio? Or if you have a trailer socket, check for water intrusion. Edited by Bazil-S, Dec 17 2012, 08:07 PM.
| Joep | Dec 17 2012, 09:53 PM Post #4 |
Trailer socket was the issue, thanks for the advice!!! without you i would never find it, plug needs to be replaced by i know completely oxidized. Also our rear parking sensors are now working again, they were failing since a week or two. But know i removed the trailer socket they are also working again. Thanks again!!! |
