electrical issues; no back lights, no front sidelights, brake pedal operating other lights.
Topic Started: Dec 23 2012, 07:27 PM (1,679 Views)
jek 64
Good afternoon, looking for some help and hoping that someone may have some information for me.
I have recently started having some electrical issues with my 2007 iveco daily, the back lights have gone out completely and when you press the brake pedal the offside indicator lights come on and stay on while the pedal is pressed, the nearside front sidelight inop but comes on when you press the brake pedal.
any help regarding this would be much appreciated
The Iron Works
I would check for a bad earth first, with all the water we have had...
big mick smith
my back lights were playing up so i took the covers off and the electrical panel around the bulbs were all corroded,the water had been getting in so i cleaned them all up and oiled all the metal bits and its been ok ,the light seal isnt very good on mine,by the way mines a 2007 tw luton van
If you have a towbar fitted ,check the electrical socket for corrosion,although I havent had the problem its a common fault and throws wierd symptoms. Paul
MrDaily
jek 64
I suggest the brake switch is faulty. Visit an Iveco service centre and have this checked
Cheers
