| Rear door hinges | |
| Tweet Topic Started: Dec 31 2012, 03:20 PM (1,206 Views) | |
| Paragon | Dec 31 2012, 03:20 PM Post #1 |
Are these mild steel or cast.. Ive cracked the inner priority opening cam around the rivet and was wondering if I could weld it. The replacement hinge from Iveco and Vexi are a bit on the expensive side. |
| v6cosworthrangerover | Dec 31 2012, 03:29 PM Post #2 |
They are the same on a gen 3 so can come from a breaker reasonably cheap second hand. |
