no plate light
Topic Started: Jan 13 2013, 05:15 PM (1,215 Views)
big mick smith
35c12 2007 tw luton van,i noticed i had a n/s rear no plate bulb gone so i tried fitting a new one,the new bulb lit up then after 2-3 seconds both no plate bulbs went out,turn lights off then turn back on both no plate lights come on then 2-3 seconds later both go out,any brain surgeons out there please help :'(
Andy™
probably wrong lamps fitted, so canbus switches them off...
big mick smith
its the ones thats been on since new and whats canbus
The lights are managed electronically by the body electronic unit. If you install a new bulb that has other values, eg: different power, the electronic unit that will cut off the bulb.
It is possible that you have installed a 10W bulb instead of 5W, or if the bulb has two filaments, maybe you've installed at 180 degrees.
big mick smith
thanks bazil al check that tmorra :D
big mick smith
bazil you were absolutely right,ihad fitted a 10w bulb instead of a 5w bulb everything ok now, ;) thanks again
