| towbar wiring; can 2012 iveco van | |
| Tweet Topic Started: Jan 17 2013, 05:20 PM (1,002 Views) | |
| saes | Jan 17 2013, 05:20 PM Post #1 |
having problems with tow bar wiring faults appered when trialer is coupled all turn any light on and everything lights up (led lights) tried fitting bypass relay but still no joy strip down and test with anything turned on iam getting 8 volts on the other lines indicators side light rear fog even with tow bar socket and bypass relay disconnected iam still getting a voltage on the lines could this be a canbus fault the towbar was fitted before we purchased the van but was wired direct no bypass relay both our trialers are led lights and it will do the same on both trialers hope someone can help |
| radiotwo | Jan 18 2013, 03:02 PM Post #2 |
Hi Saes Sorry but your post does not make too much sense, you have no comma's full stops, and needs a spell check ! If you are still having problems, can you please re-post with a better description and also saying what model you have, but describe each fault ! Radiotwo |
