| brake warning light | |
| Tweet Topic Started: Feb 10 2013, 07:08 PM (3,136 Views) | |
| flapster | Feb 10 2013, 07:08 PM Post #1 |
hello, i have just bought a Cargo Tector 75E17 2003. After i got it home (i had driven about 400 miles without problems) i noticed that whenever i press the brake pedal the orange brake warning light momentarily flashes. Also, very occaisonally the light will come on when i'm not braking, a momentary flash again, but at the same time the vehicle applies the brakes on its own ! This has happened 3 times so far in 3 weeks of driving it. The brakes appear to work fine even though the light flashes.Does anyone know what the problem might be ? cheers everyone ! |
| aidan | Feb 10 2013, 09:16 PM Post #2 |
Hi do you know if the warning light is related to Service, park or exhaust brake ? Aidan |
| Troglodyte | Feb 10 2013, 10:13 PM Post #3 |
A brake warning light would be red are you sure it's not the exhaust brake warning symbol which can be set to operate from the switch on the floor , when you release the throttle pedal or when you touch the brake pedal , on that age it would be a three position switch to the left of the steering wheel |
| flapster | Feb 12 2013, 09:02 AM Post #4 |
spot on sir ! the exhaust brake switch is what it was, i must have switched it on and didnt know what it was for. Now all i need is a user manual
