| Overhead console installation | |
| Tweet Topic Started: Feb 14 2013, 06:38 PM (2,427 Views) | |
| Andy™ | Feb 14 2013, 06:38 PM Post #1 |
Started installing the overhead console today see here for parts list http://z6.ifrm.com/4812/70/0/p1024161/Overhead.pdf i bought 3803694, bracket it came with overhead console, light, 2x visors it does not come with any screws, or items 4, 5, 6 or 7 you will need to cut into the fabric to locate fixing pointsalong the bottom there are 4x holes needed for the clips, and 4x holes for the screws / bolts. all holes in metal were already there, just needed exposed at the far sides, there is nothing to fix them to - looking at the pics from Sudesh, it appears as though the fabric roof is a different shape also, it doesnt fully over hole from existing light some pics existing ![]() whats in the box ![]() ![]() the centre support clip, bit awkward to get out - there is a screw through the centre, then lever it out ![]() some of the holes cut out ![]() there is no fixing hole nearby for this end - i used a M6x50 bolt on the LHS, but on the RHS there is no hole, so a cable tie was used ![]() almost done ![]() close up of the gap ![]() end of the day - going to cable tie the sun visor supports in place until the proper parts arrive ![]() ![]() Edited by Andy™, Feb 14 2013, 06:42 PM.
| ivecojoe | Feb 15 2013, 04:38 AM Post #2 |
Looks good to me,would that fit a mk 3? did you get it from vexi? thanks Paul |
| Andy™ | Feb 15 2013, 08:20 AM Post #3 |
got it from Vexi not sure if it will fit a MK3, but i think the cab roof is the same so it probably would |
| Sudesh | Feb 15 2013, 10:41 AM Post #4 |
35s18
Well done Andy! Good write up for anyone interested in purchasing. And yes you right, the roof lining in mine is different, as my van was specked from new with the console, I guess all those changes are made then. |
| soundmanim | Apr 3 2013, 04:14 PM Post #5 |
andy, where did you get the rear view mirror screen? that would work great with my backing up camera... |
| Andy™ | Apr 8 2013, 09:21 PM Post #6 |
bought it second hand from someone, you could probably get one from ebay |
